New Parts Topic
- Away
The points cover screws may be the only ones available anywhere with the internal lock washer on them. They are here - Kohler Points Cover Screws
Will try to do more later, time to get to work in the shop now.
- Away
- Away
Geno wrote: Also on the to do list I haven't mentioned is new throttle and choke cable replacements for the lever style controls. Been doing this here for awhile. I can make the cable where someone can just install it to and reuse the factory lever. It's a lot cheaper to do it that way if the lever is still good.
- Away
It is here - Neutral Switch
- Away
- Away
1st is the WH #101710 hood attachment rod. It works on everything I've checked so far from 1971 or so up. They run around $38 most everywhere minus a few crazies so I expect these to be around $10 and will even have clips with it lol.
2nd is the WH #102672mid attach rod. The rod is no longer available so I'm not sure if I should do the rod separately or do it as an assembly with the cam stop, spring and cap. It takes awhile to make the cam stop. What do you guys think?
- Away
- Away
