What's everybody doing?
20 Nov 2026 17:34 #19223 by Geno
Most of this week was in the 70's until this Sunday so I switched gears again.  Gotta take advantage of all of this warm weather showing up this month.
The Cobalt finished getting detailed today and put in the smaller garage and covered up for the Winter.  There's still plenty of room to walk around it and room to get dozer blades out so it worked out really good.  The CTS will get detailed and covered up as well and the Winter ride will be the Escalade as usual.  The Kubota will spend the Winter in the shop.  It will get a little work, maintenance, a good cleanup, and a few mods I've wanted to do to it for a long time then it will get covered up as well.  It already has the new Kubota quick attach top cover on it which was one thing I've wanted for a long time.  It being in the shop takes up a lot less room and gave me even more floor space.
The tractors were rearranged under the center rack and 2 of the 520-8's put together under there.  The center isle right side of the center rack that used to be cluttered up is all cleared out and there's lots of room there now.  The 753 is coming out tomorrow and getting torn down and put on a rolling shelf tomorrow.  It will be restored and turned into a tricycle that will be a twin to the one done for Bethie Pond this Winter as time allows.  After it's done it will go up front with the other ones.
21 Nov 2026 17:11 - 21 Nov 2026 17:15 #19224 by Geno
Got some more things crossed off the list while it was another warm sunny day.
We also had time to get the 753 torn down I mentioned yesterday to restore it.  Some of it was already apart so it wasn't too bad.  It's a super nice tractor with nothing more than some surface rust so it will be a super nice one when done.  There's still a few things that still need to come apart but it's mostly done.  It's on a rolling shelf and I can work on it in spare time this Fall/Winter.  I'll start a post on it in the Resto Section when I get started on it.
I'll be out of the shop some of next week to get some other things done but will be in the shop some too.
Last edit: 21 Nov 2026 17:15 by Geno.
23 Nov 2026 17:19 #19225 by Geno
Went to the Chiro peeps, filled propane tanks, ran errands, then started piddling with little things in the shop I've been meaning to do for awhile.  Started a good cleaning on the work bench and got a newer style 8 speed tower ready to weld back together tomorrow that I took apart years ago to press the lift arm off of the shaft.  I always break 1 end loose so it can be fitted back together to get it right like in the pic below.  It makes things a lot easier to do it that way.
