What's everybody doing?
04 Nov 2026 18:10 #19195
It's already after 7 Geno time (I never change my clocks) so I have to head out. Picks of the beginning of this little idea in the last post are on the camera so I'll put them up tomorrow morning here for an idea of what's going on, and start a separate post on it as well to keep it all together.
09 Nov 2026 17:47 #19205
Got a late start again today, meant to do this sooner but it's been super busy around here. The details of the shelf project on the 4 post rack/shelf are in their own post here -
New Shelf Project
12 Nov 2026 06:17 - 12 Nov 2026 07:29 #19210
The numbers of peeps showing up here every day still amazes me. These numbers are in real time throughout the day. This is the 7:08am group this morning.
EDIT - It's now 8:26am so here's that group in the 2nd screenshot.
Last edit: 12 Nov 2026 07:29 by Geno.
13 Nov 2026 09:43 #19212
Thats a lot for sure and i needed to do some mulching here for the first time but i have too around 4 times every year. So i walked kicking leaves looking for anything i would run over and i find nothing.....Well the mulching starts and in about ten minutes later i hit something so i stop and get my hand under the deck on a blade and what i feel is a umbrella wrapped around everything. I hope i never run over another one in my life time...Nuff Said..
13 Nov 2026 12:33 #19213
13 Nov 2026 17:50 #19215
Enough parting out for now, I'm tired, have other work to do, and am tired of the mess...
My friend Kevin is coming up tomorrow and we're making cradles for the blaster + vac. I had to clear the big bench so the engine parts went on a pallet and the other disassembled tractor parts went on 3 of the the 4' 3 shelf rolling carts. Everything is stuffed to the brim on those along with the small welding bench, tool box, a tall 6 shelf 4' rolling cart, and some red roller carts like in the pic waiting for me to deal with it which will start next week.
It's been a long road over the past several months inbetween other work but my crazy vision has been accomplished. There's plenty of room for all the parts in a lot of different spots in the shop, a lot more room in the lot, smaller garage, 4 car garage, and a lot more floor space. Once the parts are dealt with on the carts, the carts go in the back of the shop and that floor space will be empty too.
Starting next week will also be testing a lot of things like starters and such to see what's good, and just general clean up of the place so we can move on to other things on my list...
14 Nov 2026 07:14 #19216
That sucks, hope it comes out easy.
Yeah it didnt.......A PAIN IN THE YOU KNOW WHERE....BUT ITS ALL OUT.......
14 Nov 2026 17:50 #19217
Glad you got it Nappy.
Kevin was up today and we got the cradle for the blast cabinet made, it sure does roll easier with the 4" wheels on it. The cabinet wasn't quite square so we built + tack welded the frame on the cabinet so it would fit right. It's all back together and ready to blast again. We'll do the vac + anchor it to the cabinet next time. Once done just 1 unplug for the main power and undo the air hose if need be and the rest can all stay together and move anywhere. I may put a longer heavy extension cord on the back as well. There's plenty of air hose hung on the rear of the cabinet so it can be moved quite a bit while leaving that hooked up. The big thing is making it easy to move to put motors + transmissions in it on the trolley for blasting.
I'll prob put a post up in the tool section later on this as well in case someone else wants some ideas.
16 Nov 2026 17:33 - 16 Nov 2026 17:35 #19221
Putting away and blasting more parts as usual here lately. The mountain of head bolt washers for the big + small blocks are all blasted except the ones I haven't found yet...
Also brought in a tractor with a Tecumseh engine to test starters on tomorrow. The engine will get pulled in the morning and will prob stay inside and together just to test things on.
Also ran up on 20 old style tail lamps brand new in the box that were delivered last Friday. I went through them and repackaged them this morning. The leads were separated from the lamps and put in plastic bags so the lamps didn't end up damaged. The lens, built in ground to the bolt, and where the wire comes out is the same. The lighting is a newer style with 2-194 bulbs instead of the single older bulb but brighter is fine with me. I was mainly after the lens that looked the same, the entire lamp assy was just a bonus.
Last edit: 16 Nov 2026 17:35 by Geno.
17 Nov 2026 16:58 #19222
Did some more hub blasting and clean up on the lathe this morning while my neighbor was taking the Tecumseh off the 700.
We tested all of the starters in the shop and ended up with 5 good ones and a lot of good extra parts off of the bad ones. We just used the high amp switch off of the tractor and a battery to do the testing but I wanted to do the testing on a motor to check them under a load. Free spinning isn't a good test without a load. Some of the good ones had to have the bendix parts removed and blasted for them to work right but that's all done and they're ready to go. I may pull all of the bendix parts off all of them and blast them and the starters while they're off at some point this Winter whenever time allows.
