What's everybody doing?
29 May 2026 12:06 #19032
Got to meet with someone to talk about Medicare options today... Maybe if I sign up with someone the telemarketers will quit driving me absolutely crazy. Some days there are 12-14 calls a day, wears me out cause I'm the don't call me I'll call you type...
Finished up some more painting on Carson's this morning, parts are coming in to rebuild another toilet that's 30+ years old from the house, and the upstairs heat pump that cools the entire house quit last night. I checked it out this morning and it's just the start capacitor. I ordered one on Amazon and it will be here tomorrow. It's a little 2 ton unit was put in early 2008 so it's done real well, this is it's first part on the unit. One bedroom upstairs is a loft open in the entry way and the whole house stays the same temp with just that little guy because cold air drops and the house is foam insulated like the shop.
The only thing the toilet really needs is the 30 year old flapper replaced but I figured everything else lasted long enough. It's super thick, heavy, and Made in USA, nothing like the cheap China stuff...
30 May 2026 17:50 #19034
Took today to do some much needed repairs and misc stuff. Rebuilt the toilet, fixed the upstairs heat pump, put the old fridge back together to get all the old interior parts out of the house, mowed after almost 3 weeks again, did a little more tree trimming, and a bunch of other little things on the list. I get to enthralled with the Wheel Horse stuff and little loose ends and things I need to do don't get done. I need to quit a little earlier each day like 6pm instead of 7 or later and try to have a little time to do things like normal peeps do...
01 Jun 2026 18:14 - 01 Jun 2026 18:57 #19035
This is one of those days I think about running home screaming lol...
There is such a thing as too much business and I have to figure out how to slow it down. I've had this problem with every business I've owned, and I thank the Lord and am blessed to be sought after like this but I have to figure out where to draw the line. I did get Carson's sheet metal for the engine blasted early this morning then it went crazy. Peeps wanting tractors built, wanting parts, one that wanted to come to late today but it's too late so he's coming in tomorrow morning, voicemail messages that still have to be returned but it won't be today... I talked about this in my post here from last Sat and it's even more out of control today. I think someone is trying to help me realize it's time for some kind of plan to have at least a small life outside of work. My biggest problem is prob myself and not saying no or I don't have time enough.
I have things I need to do. One of them I would like is lunch... I didn't even get lunch 4 days last week, or today and my stomach is growling right now. I am hungry and need to at least eat and I like my pant size and don't want it going down more... I also love mowing and it would be nice to mow more than every 3 weeks. All I want is mostly necessities that every one else takes for granted lol.
I think I'm leaving now and going to make something to eat.
Last edit: 01 Jun 2026 18:57 by Geno.
02 Jun 2026 19:55 - 02 Jun 2026 19:55 #19036
Another wild day, last 2 peeps just left and it's 7:53, or less than 40 mins to bed time that I need to wind down. I'll try to get updates on Carson's tomorrow afternoon. Got more done but pics are still on camera and time to run again...
Last edit: 02 Jun 2026 19:55 by Geno.
03 Jun 2026 09:36 #19037
I returned all the phone calls for the past few days and I'm running for the truck.
I need a little time away so I'm going groc shopping and wander around away from here until lunch time.
08 Jun 2026 18:28 #19045
Turned a hub for someone, it was up against a rearend at some point and had hammer marks on the outside. Not sure how the outside got the center cut back it has on the outside but it's still a good hub.
Spent the rest of the day catching up on blasting little things and a motor for someone inbetween phone calls. The new trolley in the blaster made it a lot easier to do and held it no problem.
12 Jun 2026 12:56 - 12 Jun 2026 12:58 #19048
More samples from the guys in Germany I deal with that make the fancy bushings came in yesterday. These are a hair over 7/8 OD x 3/4" ID. They are not split but a press in style. They will fit the steering wheel bushing spot and go in by hand on any of them that have a little wear, or can be lightly pressed in. I ordered these to get away from the original steel bushing usually used that caused Carson's C-121 steering to rust and lock up to where it even broke the steering wheel. I didn't order red, they just happen to be made in red which is cool with me...
I also ordered parts from Blast-it-All to fix the blaster this morning. They will be here beginning of next week. Also just ordered another 50lb bag of aluminum shot at almost $400 now... Considering how long it lasts it really is a bargain though...
Last edit: 12 Jun 2026 12:58 by Geno.
13 Jun 2026 18:52 #19049
Kevin was up here helping me again today. We changed a lot of things on the blaster while it was down again that Transmet Corp (peeps that make the aluminum shot) recommended. I'll post the changes next Monday in the blaster mods post. I also found another bad part in the metering valve last night. Pirate Brand makes rebuild kits for them and I ordered one this morning from Tractor Supply. It has to be shipped to store but it was $5 less, no freight, and would be in the store next Thurs, just as fast or faster than anyone else.
Everything else on the blaster will be done by then. I'm also adding a union to the bottom of the pot so I can move the metering valve handle where it's easy to get to if the blaster gets moved again, or I ever need to take the valve off again. Gotta think forward because I never know what I may do in the future... The metering valve (how much media is put out) is on the bottom of the pot. It's in the pic below. It was extremely tight and was a pain to get off with the legs in the way. Once the union is in there it will only take a minute to move or remove.
15 Jun 2026 17:40 - 15 Jun 2026 17:41 #19050
The problem in the metering valve is in the pics below. I have a rebuild kit coming but the main problem is the insert for the main valve. In the first pic you should see a black piece inside with a round hole in it but it is completely gone. I found a pretty good pic of what it should look like (last pic) and the pieces on the bench is what it is now...
Last edit: 15 Jun 2026 17:41 by Geno.
17 Jun 2026 18:27 #19051
This has sure been the week of distractions. Mondays are usually crazy because of the weekend and yesterday was more of the same. I unexpectedly had someone that I spent most all of yesterday afternoon with. It's not a terrible thing but I want to get the blaster fixed and get back to Carson's 121.
The popup valve and seal came in today along with the aluminum shot and 600 new clamps I ordered last week. 600 was all they had. The metering valve rebuild kit is supposed to be in tomorrow.
Kevin and I worked on some mods for the blaster last Sat while it was down again. We made 2 new suction tube plates and did some other things. I'll put that in the blaster post soon as I get a min. I got the new bottom pipe piece on the blast cabinet sealed up and on today. Transmet (peeps that make the aluminum shot) said they have a blaster just like mine, and others they experimented with and while going from 5 to 4" ID helped a lot 2" was the sweet spot on mine to make it really go. They did a lot of experimenting like I did to make pressure blasters pull up the aluminum that weren't made to do so, just more in depth in order to sell more product. Smart guys.
I ordered the clamps from the same peeps that made the bigger ones for Wheel Horse / Toro. These are 1/4" and fit a spark plug wire perfect the way they are. I figured they will have a lot of uses on the tractors like the throttle + choke cables, plug wires, wiring harness, or anything else smaller. Wheel Horse used the bigger one on the throttle cables on all of of the newer tractors and these will look and fit better as well.
Time to create page: 0.173 seconds
