New Techy carbs
- Away
I guess it would help to know that this paticular tractor doesn't have the original Techy. Someone swapped the original Techy with another Techy! :confused1 :beat
Geno wrote: The most popular carb numbers are 632230 / 632272 and are interchangeable. It won't have a primer on it Justin.
Geno do have any engines laying around? I'm tired of messing with these Techy's! All I want to do is mow my lawn! :angry2
- Away
What are the engine numbers on that thing.
Ok then AJ that second carb will work. They are all the same size for those. Just make sure its for the same model # on the engine.Geno wrote: The most popular carb numbers are 632230 / 632272 and are interchangeable. It won't have a primer on it Justin.
Ok. All you need is the model number on the ENGINE. Then I can check for you. If it isn't I can find one for you too.AJ WH Ranger wrote: Not sure on the numbers. I will look when I get home.
- Away
Geno wrote: This one fits the most popular numbers for the H50, H60 + HH60 - Link
Just bought this carb... Hope it does the trick!
