New Parts Topic
- Away
04 May 2018 15:11 #14595
New Parts Topic was created by Geno
Since I am a little back in go mode I'm gonna try to keep all the new stuff to this one topic instead of several. :rolling
The point, point cover screws, and air filter base screws arrived today. I kept the point cover screw the same for looks, internal lock washers for them are on the way. I changed the filter base screws to phillips drive so they are easier to get in there, I'm tired of chasing them around the shop.
They have the internal lock washer built in and are stainless steel. I got 1,000 of each so they should last awhile.
- Away
04 May 2018 15:13 #14596
Recap of the new grip -
Just added the PTO engagement grip \ snow thrower chute turning grip to the store today. They will fit anything that has a 1/2" diameter rod.
They are here - Grips
- Away
04 May 2018 15:16 #14597
- Away
04 May 2018 15:20 #14598
Recap of bushings -
The replacements are here and work great, just push it in by hand. No hammering in or chance to damage a $14 bushing. Self lubricating, quick and easy.
They fit a lot of places on the tractor like the PTO shaft, brake shaft and automatic shafts. I'll have them in the store soon for $6.99 or so.
- Away
04 May 2018 15:24 - 04 May 2018 15:30 #14599
I really never put this in a topic so here it is. Custom battery cables made here in house with all made in USA components. The cable is color coded red or black and is 6 gauge pure copper welding cable. A little overkill but too much is better than not enough and the tractor sure turns over a lot faster with them.
Last edit: 04 May 2018 15:30 by Geno.
- Away
04 May 2018 15:34 - 04 May 2018 15:35 #14601
Never posted this one either oops.
Now making custom plug wires from all made in USA components. All boots are silicone and the wire is copper with a silicone jacket. I used an automotive grade clip for the spark plug with a spring reinforcement so it wouldn't spread out or get loose over time.
The coil insert is wrong in the pic of all the parts but I have the right ones in stock now.
Last edit: 04 May 2018 15:35 by Geno.
- Away
04 May 2018 15:37 - 04 May 2018 15:38 #14602
And there is more still going on and in progress, I guess I have been busy the past month lol...
Now I just need to get pics and stuff in the store.
Last edit: 04 May 2018 15:38 by Geno.
04 May 2018 16:29 - 04 May 2018 16:32 #14603
Replied by motor12 on topic New Parts Topic
I'm always looking for little things like OE point cover screws. looks like you may be busy just making custom battery cables. I want to look at any of your kohler K90/91 stuff if you have any at your June event.
Last edit: 04 May 2018 16:32 by motor12.
- Away
25 Aug 2018 18:01 #14824
Working on the store today. Some of the new items are the Kohler throttle swivel, Kohler choke clamp, Kohler air filter rear plate screws, a basic inline fuel shutoff, and getting ready to do a basic 90 degree shutoff. I have a little over an hour left out here today so I may get a few more done.
Working mainly in the fuel section this afternoon, it is here - WHS Store Fuel Section
- Away
25 Aug 2018 19:10 #14825
Last one for today was the Clear Fuel Filter, nothing like seeing what's going on, it's like xray vision, sort of lol. :rolling
