Gasoline Additives
- Away
MMO in my world means massive multiplayer online. :smile2
Marvels Mystery Oil. Really good stuff AJ. I would recommend putting it in your gas and oil. In my opinion its a LOT better than that sea foam crap. Last time I used that stuff I had to clean the carb in my snowblower because it crapped it up. MMO is WAY better.AJ WH Ranger wrote: Wait, what is mmo for the uneducated such as my self?
AJ, sorry about the MMO abbreviation, it's what a lot of us old timers call Marvel Mystery Oil, a good upper cylinder and valve stem/guide lube.
I personally think this is a great learning experience and may answer a bunch of questions for future use.
AJ WH Ranger wrote: What is the benefit if it is a "good upper cylinder and valve stem/guide lube". Why would one want that in the fuel/carburetor? Educate me or anyone else that may be lurking?
AJ here is the best explanation I can give. The upper cylinder is the area above the piston rings at any given portion of their travel and is therefore not lubricated when the piston moves up in the cylinder. Any part of the cylinder above the top ring is dry, that's why lubrication in the fuel is important. In the old days we had leaded gasoline and lead was a wonderful low friction lubricant but those days are gone (thank you EPA). The same is true for the valve stem and guide, there is no oil in the intake or exhaust area unless it's provided by the fuel. Hope some of this makes sense.
Makes perfect sense!! Thank you! I can now see why that would be very beneficial!
Major doesn't it clean the oil and carb, and also cleans up old oil in valve stems and guides?M Bailey wrote: Geno, many years ago I raced a 250 Bultaco flat tracker and always used Klotz castor based 2 cycle oil in it. A bunch of the old timers at that time swore that castor mist would stick to mosquito wings preventing them from flying. I've used it ever since (the smell reminds me of the flat track). Castor has a high flash point and passes through the combustion chamber pretty much intact and doesn't harm rubber in fuel lines and pumps as an added bonus.
