Solenoid help
- redone
- Member
19 Nov 2016 07:20 #12715
by redone
Solenoid help was created by redone
All of a sudden. 105 wheel horse. Start engine. Push down on foot pedal. Turn switch. Let off pedal ok. Push down on pedal.starter engages while engine is running.
I removed solenoid replace new. Just a standard 12,volt solenoid. Dose not operate as older solendoid.
Dose small engine parts only designed for small engines especially kohlers. I have never had this problem before...
thanks for your help
Bill
Bill
19 Nov 2016 07:41 #12716
Replied by Geno on topic Solenoid help
Morning Redone.
Sounds sorta like the ignition switch may be staying engaged in the start position when it's not supposed to. You can check that with a test light easily.
- redone
- Member
19 Nov 2016 10:28 #12719
by redone
Replied by redone on topic Solenoid help
Geno, I had replaced my switch when we rebuilt the wiring harness. Actually I found a switch from a John Deere that works. (New.) I guess I'Ll have to go back to red painted one.
P S I like this new wheel horse web site, takes me a while to roam and find people.
this must be all very new?
Have a great Thanksgiving.
and thank a,vet.
Bill
Iowa
and thank a,vet.
Bill
Iowa
19 Nov 2016 11:07 #12720
You can take a test light to the S terminal, the one at the top all by itself and see if the light goes out in the run position like it should. Also make sure that's the wire that goes to the start circuit.
I've talked to a lot of people in Iowa recently, are you one of them?
Time to create page: 0.080 seconds
