- 23 AUTOMATIC LSE
15 May 2017 16:06 #13714
by 23 AUTOMATIC LSE
Here's a sneak peek at the decal on the hood.
16 May 2017 05:26 #13715
good idea and I still have mine for my 1985...................:agree
16 May 2017 08:02 #13716
Wow you are moving right along Mark, looks awesome woot.
- 23 AUTOMATIC LSE
17 May 2017 16:45 #13722
by 23 AUTOMATIC LSE
Thanks, Geno I have some Woodruff keys on order I am supposed to get a call to let me know they are ready for pick-up may be a week, though. I have to get the one tire that leaks, unmounted to get it rewelded and refinished then remount it, I also have to mount the other two ags to the other two wheels. Can't wait!
- 23 AUTOMATIC LSE
27 May 2017 13:54 - 27 May 2017 13:56 #13766
by 23 AUTOMATIC LSE
Woodruff keys arrived, ordered 8 so I now have an extra set. These appear to be the same as the ones for the 953, 1054(A) GT-14 and 18 Automatics. I am hoping to get the 2 hubs that I will be using on the outside off of the axles that they are currently on. Thinking of having a go at soaking in some Acetone/ATF 50-50 mix, for a while, then having neighbor press them out. Will have to wait and see.
Last edit: 27 May 2017 13:56 by 23 AUTOMATIC LSE.
28 May 2017 18:23 #13773
One more thing conquered.
- 23 AUTOMATIC LSE
02 Jun 2017 20:11 #13807
by 23 AUTOMATIC LSE
Just a bit of an update, as I am currently awaiting some rear wheel weld repair and tire mounting, I decided to skip past steps 189 through 213 and proceed to assemble some parts to the frame.
214.) Steering column support Assembly
215.) Hex Bolts
216.) Nyloc Nuts
217.) Installed on frame
218.) Ross steering column
219.) Worm gear housing
220.) Upper ball bearing race
221.) Upper ball bearings/keeper
222.) Shaft
223.) Lower ball bearings/keeper
224.) Lower ball bearing race
225.) Spring Washer
226.) Adjusting plug
227.) Retainer
228.) Seal
229.) Installed
230.) Stud
231.) Lever
232.) Stud nut
233.) Installed
234.) Washer
235.) Installed
236.) Hex nut installed
237.) Lock nut
238.) Lock nut installed
215.) Hex Bolts
216.) Nyloc Nuts
222.) Shaft
225.) Spring Washer
227.) Retainer
228.) Seal
229.) Installed
230.) Stud
231.) Lever
232.) Stud nut
233.) Installed
234.) Washer
235.) Installed
237.) Lock nut
- 23 AUTOMATIC LSE
02 Jun 2017 20:34 - 02 Jun 2017 20:42 #13808
by 23 AUTOMATIC LSE
The manual does not include the hex bolts that secure the column to the support assembly, nor does it give part #'s for these 3 bolts.
239.) Hex bolts
240.) Mounted on support
241.) Hex bolts installed
242.) Upper steering column bearing {These last 2 pics were inadvertently left out of the previous post.}
243.) Installed
239.) Hex bolts
243.) Installed
Last edit: 02 Jun 2017 20:42 by 23 AUTOMATIC LSE.
- 23 AUTOMATIC LSE
03 Jun 2017 09:16 - 03 Jun 2017 09:22 #13809
by 23 AUTOMATIC LSE
Drag Link:
244.) Drag link end {Non O.E.M.}
245.) Drag link
246.) Drag link end Installed on Drag link
247.) Drag link end on bell crank
248.) Drag link attached to drag link end on bell crank
249.) Drag link attached to steering lever
245.) Drag link
Last edit: 03 Jun 2017 09:22 by 23 AUTOMATIC LSE.
- 23 AUTOMATIC LSE
03 Jun 2017 11:41 #13810
by 23 AUTOMATIC LSE
Neutral Return Pedal:
250.) Parts
251.) Shaft
252.) Right bearing
253.) Inserted in frame
254.) Ditto Left bearing
255.) Shaft installed
256.) "E"-Ring clip
257.) Installed on left end of shaft
258.) Shaft in right side
259.) Spacer
260.) Neutral return pedal
261.) Positioned on shaft with spacer
262.) Roll pin
263.) Positioned in hole
264.) Inserted
265.) Spring / anchor plate / bolt & nut installed
250.) Parts
251.) Shaft
252.) Right bearing
256.) "E"-Ring clip
259.) Spacer
262.) Roll pin
264.) Inserted
