Roll pin size
GT 14 wrote:
I have a 20T but you need a hole in the hub. Probably go with cut and coupler, that way I can have a perfect lined up wheel.
Oh....I bet there is a hole there.....I have pushed through the plastic on some.....used to pull wheels for Jdog....
They get pretty tight after a couple decades.....nappypappy wrote: I was thinking about replacing my steering wheel on the 416 and I did see the roll pin but should the wheel pull off after pin is removed?
The C175 is a solid wheel Bob. This is the one I knocked the pin out of a little to get a measurement for GT.
Geno wrote: Nappy's came off in less than 1 minute in the press. Makes it easier to do the wiring and get it where it belongs with all of the panels out of the way. Your wheel looks great Nappy, just needs a cleaning and center cap.
Just saying I have punched through is all....got to punch through the plastic....the coupler will be an interesting trial....lots of torque on that shaft.....
Free at last Free at last
The reason for all the work! Now for some prep and paint!
Geno wrote: Very nice. How bad was it? Always wondered if they would be easier because they couldn't get water in the top. :confused1
It took everything the press had and resisted all the way, and that's after a two day soak.
