Going through another tiller
There was a single needle bearing missing on the input side of the input shaft, and no seal at all, no seal was even installed. The bearings also ran sideways because of this and damaged the input shaft... There was also a single needle bearing missing from one of the rear shaft bearings, and the other rear bearing was locked up. The input shaft retaining clip was sprung and the gear and shaft were walking around.
I'm getting ready to get out some new bearings, clean up the shafts, and see what we got. And YES, someone has been in it before. :angry
:rolling
This is the one I just bought and thought it would be easy... I have several people coming this weekend and one person wants a tiller with a tractor and some other things so I thought I would fix it.
- Kurt-NEPA
Kurt-NEPA wrote: New bearings, seal, and paint and will be like new. Somebody's getting a nice tiller!
Yeah you right....he does great work and a great person on top of that even if he is a hoarder.................:smile2
I used the clean up the shafts on the lathe trick, that thing comes in handy and does things fast. The seals should seal and the main input shaft should be ok, you can see the little ridge on it where the bearing damaged it from the needle missing but it's very slight. We have all of the parts in stock NOS to do several of these. Will let the paint dry overnight and put it back together tomorrow.
Someone from Ohio, it's on a note here somewhere... I was thinking of you cleaning the shafts that you would be proud lol. :rolling
How can I fix and save stuff if I don't hoard stuff?
Well you do have a point there... and there's a fine line between hoarding and running a business like yours...so the way I see it is its hoarding till somebody needs something then its a business deal.......................and on the other hand I wish I could hoard like you and make money at the same time......:smile2
- Kurt-NEPA
Geno wrote:
I was thinking of you cleaning the shafts that you would be proud lol. :rollingKurt-NEPA wrote: New bearings, seal, and paint and will be like new. Somebody's getting a nice tiller!
Finally we see some lathe work. Well done,
Kurt
