The Dreaded Kohler Knock-Rattle
The factory method requires removing the engine and oil pan and measuring the side clearance with a feeler gauge, which is not necessary if you have a dial indicator as shown below.. With the PTO engaged zero the dial indicator, then disengage the PTO and pull the PTO clutch outboard and check the dial to see how much lateral play the crank has. Repeat this procedure after re-shimming to verify the end play.
In this case I removed .035" of paper shims to get the clearance back to specs. Be sure to measure the shims with a micrometer and subtract the correct amount to achieve the desired end play. White shims are anywhere from .010 to .015, black shims are .030 but use a micrometer to be sure!
You can see that this engine has been torn down before because of the dinged up crankshaft end, probably for rings/piston/rod replacement.
Hope this helps someone out there fretting about their knocking Kohler. Oh! The bottom line is, this one doesn't knock any more!!
Yeah it does have plenty of power and guess I will check plug and stuff................:smile2Geno wrote: The engine on yours sounds great Nappy. If something doesn't seem right it will be outside the engine like a plug, plug wire, carb, etc.
- FewMoreMiles
- Banned
FewMoreMiles wrote: Interesting and informative post, Major...thanks for taking the time to share the details and photos. Curious...the "knocking" is simply the PTO traveling on the crank essentially? I have never experienced this sort of thing, but would be curious as to what is actually happening. Does it actually sound similar to a low end motor concern...maybe like a rod knock? Thanks!
Jeff, what causes the knock, which is sharp and hollow sounding, is excessive side play in the crankshaft causing it to move from side to side on the main bearings. When the PTO is engaged it forces the crankshaft to seat on the left side main bearing, eliminating or greatly reducing the knock.
