Another 520-8
13 Jul 2023 17:45 #18076
Replied by Geno on topic Another 520-8
Started getting it ready for the steam cleaning day I have planned one day here in the near future when the weather is right. Other than the rear fender and side panels most of the tractor will clean up like new other than the faded hood. The tower, frame, brackets, etc, have no rust at all, just dirty and it can be wiped off by hand. I've been trying to figure out why so much of the tractor is like new and some panels are so rough, I still don't have an answer for that...
It has too long of a belt on it that someone has changed. The clutch shock is gone and the brackets bent out of the way just to get the long belt to pull it, (2nd + 3rd pic) and it's still not tight enough. That stuff is all being taken off anyway so it's no biggie. All of the broken bolts are out, a lot of parts are off, the motor is loose, so now I need to spin it around sideways to get the rear wheels and pulleys loose then it can get cleaned up.
I got another wheel on the right front (it had a 6" wheel with the bearings knocked out of it on there prob just to push it around) and there was no damage to the axle so that was good. Everything on it at least works now, even the hour gauge, so with some TLC it should be a good tractor when it's all done.
14 Jul 2023 18:27 #18077
Didn't have time for much today but it is all ready for the first pass with the steamer. Pulleys and rear hitch are off or loose, fuel lines, tank, etc is all off. The clutch shock brackets are also off and the rearend is drained.
The Wheel Horse bracket and parts for the chipper also got blasted. After looking at all the weld spatter you guys know what was next... I spent about another 30 mins cleaning that off and put it back in the blaster again. I really wish I wasn't so OCD sometimes lol.
18 Jul 2023 17:36 - 18 Jul 2023 19:15 #18078
I'm gonna add some categories to the attachments section and clean it up a little in the next few days. After that I'll keep the chipper updates in there. But for now, the Wheel Horse adapter for the chipper got painted up and finished today.
Last edit: 18 Jul 2023 19:15 by Geno.
18 Jul 2023 19:08 #18080
I went on and cleaned up the attachments section and added a few categories. It got done quicker than I thought, I'm trying to do better lol.
29 Jul 2023 15:59 #18085
Just a little work done on it today. When it gets too hot outside after lunchtime like it has been here lately I go in the shop where it's nice and cool and find something to do. The rearend is all apart, shafts are polished, seals removed, and a few parts blasted. I wanted it apart to dry out this weekend in case the steamer got a little water in there.
I'm hoping to get the rearend and all the parts for it painted next week so I can get it rolling again. After that I can remove the motor and start taking the shields, flywheel, etc, off and get it back out to the steam cleaner.
31 Jul 2023 16:54 #18086
Been working on it on and off through the day but everything is painted, new seals are in, and shafts are lubed up and ready for assy. All new hardware and shift boot is laid out and ready. Will put it together tomorrow when the paint dries completely.
01 Aug 2023 15:45 #18087
It always amazes me how with some proper cleaning, painting, and new hardware how well these turn out. It just takes a little time + patience.
04 Sep 2023 18:22 - 04 Sep 2023 18:23 #18103
Took some time over the past few days getting the shields off the motor and it looks like nobody's been in there messing with things, good news. The motor is on a cart that has the next wave of small parts for steam cleaning being put on it, shields are all blasted + ready. There's some dirt under the flywheel but no leaks I can see anywhere. I have plenty of starters to replace the original one with, the original works fine, it was just beat up a lot from whoever thought that was the problem...
Last edit: 04 Sep 2023 18:23 by Geno.
27 Sep 2023 19:12 #18133
I had the steamer out yesterday for the 417 I'm working on so I did a few other little things including the engine and a few other parts for this one. The flywheel and the last parts that needed blasting are done, and everything is cleaned up and ready to go back together. All that's left is painting some engine parts and shields and it can go back together.
Time to create page: 0.345 seconds
