15 minute throttle lever fix
15 Mar 2016 19:20 #10856
15 minute throttle lever fix was created by Geno
I should have put this up before but never did. Just got through doing the 520 we'll be mowing with this Summer so thought I would grab a pic.
Remove cable.
Drill rivet.
Insert bolt with lock washer and lock nut.
Use speed clips and screws to reassemble.
Job done and it is adjustable from now on.
Remove cable.
Drill rivet.
The following user(s) said Thank You: jimmyman60
15 Mar 2016 21:20 #10857
Replied by Kurt-NEPA on topic 15 minute throttle lever fix
I like the speed clip technique. I think I will steal it.
15 Mar 2016 22:41 #10858
Replied by Geno on topic 15 minute throttle lever fix
Steal away lol. A lot easier than trying to get those dang nuts on. :rolling
- jimmyman60
- Member
04 Aug 2018 22:05 #14784
by jimmyman60
Replied by jimmyman60 on topic 15 minute throttle lever fix
I just did this on my 1988 416-8 this afternoon. I used a 1/4-20 bolt, flat washer and (2) 1/4-20 nuts (one was a jam nut with loctite because I didn't have a lock nut). It worked great and the throttle now stays at full throttle now. I can now see why you say to use the speed clips. Those little nuts were pretty tricky to get back on.
Thanks for the idea Geno!
05 Aug 2018 08:30 #14785
You're most welcome Jimmy. Glad you got yours fixed.
Time to create page: 0.322 seconds
