New Template
05 Jan 2017 08:47 #13018
New Template was created by Geno
I'm using this topic for testing also. There's something slowing the post process, it takes too long once you press the submit button for the post to happen. It's been doing that for a little while and I think it's the interaction with another module.
So what are your thoughts so far? Is everything user friendly? Is there something else that needs work? :read1
05 Jan 2017 08:50 #13020
Replied by Geno on topic New Template
Well the posting is lighting fast now.
It was a conflict with the calendar module at the bottom of the forum page. I removed the calendar from the bottom of the forum page before I started this topic because I though that may be the problem. The calendar is still in the main menu and on the front page.
05 Jan 2017 10:13 #13022
Thanks Motor. If you see anything that could be improved on please let me know.
05 Jan 2017 11:10 #13024
Replied by GT 14 on topic New Template
So far so good, will continue to browse.
05 Jan 2017 12:28 #13027
The only improvements I can think of is in your shop and clearing out some more stuff you don't need.......... :wsnow :hungry :scared
Replied by nappypappy on topic New Template
Geno wrote: Thanks Motor. If you see anything that could be improved on please let me know.
08 Jan 2017 14:44 #13057
There was a problem with the text at the top of a section or new post overlapping, just got that worked out. I think that may be it. If anyone sees anything else let me know.
Time to create page: 0.673 seconds
