Worn Spindles
20 Apr 2015 05:35 #3529
Worn Spindles was created by GT 14
The underside of my front wheel spindles are grooved from neglected bearings. One solution I was considering was to sleeve them and use oversize bearings.
Ideas please.
Ideas please.
20 Apr 2015 05:48 - 20 Apr 2015 05:57 #3531
Replied by Trouty56 on topic Worn Spindles
Last edit: 20 Apr 2015 05:57 by Trouty56.
20 Apr 2015 07:17 #3532
Yes I did, had read your post and liked the idea but figured sleeve and oversize bearings would be allot cheaper. Still thinking about it tho, was the surplus store where you got the hubs online?
Replied by GT 14 on topic Worn Spindles
Trouty56 wrote: Have you considered hubs???
www.wheelhorsestables.com/index.php/foru...wheel-hub-conversion
20 Apr 2015 07:57 #3537
Replied by Geno on topic Worn Spindles
I would weld up the grove and grind it off to repair the spindle.
20 Apr 2015 09:39 #3549
Its pretty nasty, don't think previous owner had a grease gun.
Geno wrote: I would weld up the grove and grind it off to repair the spindle.
20 Apr 2015 09:58 #3551
Looks like the hubs I used are out of stock.....probably had a supply of them and sold them all......
www.surpluscenter.com/Wheels/Spindles-Wh...-BEARINGS-1-3747.axd
Next best thing are these......
www.surpluscenter.com/Wheels/Spindles-Wh...UB-4-BOLT-1-1133.axd
cost 2x as much......bummer
20 Apr 2015 10:28 #3553
That's the nastiest mess I've ever seen GT. The inner bearing surface looks ok, all you would have to fix is that deeper groove and where the bearing sits on the outside.
20 Apr 2015 11:14 #3555
Replied by M Bailey on topic Worn Spindles
That one's as mangled as any I've seen GT. Think I'd find a used one or cut that one off and weld on a new spindle stub. :cents1
Time to create page: 0.507 seconds
