Bethie Pond's Baby
06 Jun 2020 18:44 - 06 Jun 2020 18:44 #16072
Replied by Geno on topic Bethie Pond's Baby
2 sets of NOS production ring sets showed up this morning, motor is close to done.
Does anyone else put grease on the end of the slinger and make sure it doesn't hit the oil pan before assy?
Last edit: 06 Jun 2020 18:44 by Geno.
06 Jun 2020 18:48 #16073
It's ashamed to use the grade 9 stuff then just cover it up.
06 Jun 2020 18:53 #16074
Covers are on and almost there. Never did a black engine with a red generator and bracket, I think I like it. Never did a chrome coil bracket either lol.
08 Jun 2020 13:02 #16076
Only 1 part on the whole engine made in China and it was no good... :angry Couldn't get the engine to run right, till I put the original carb back on it that is...
08 Jun 2020 20:16 #16077
I just listened to this... The recording sounds like it has a loud lifter tick or noise but it doesn't sound that way for real. I know it setting on the metal bench enhances things but I don't know if the camera enhanced it more or Youtube did it. I hate all this tech that trys to make things "better" or "fix" things lol. I'll get another recording of it when it's on the tractor and on the ground.
09 Jun 2020 18:58 #16078
Wow, the things I can get done when it's quiet and the phone falls off the hook for a bit.
Started out the morning changing the oil, getting the motor mounted and starting on the wiring harness and battery cables. Also had to make a special thin head bolt for the clutch idler pulley, grade 9 should do it lol.
09 Jun 2020 19:04 #16079
The wiring harness is pretty much done and a lot of little odds and ends are finished up. The hood was put on and tank adjusted and tightened up, return spring for the brake, stirrups, generator belt cover and the seat is on. I even did a little pipe work to make the oil easy to change, just for you Bruce.
10 Jun 2020 12:45 #16081
It's getting close to done so moving it out to the public view.
10 Jun 2020 18:58 #16082
It came together really quick and everything is working great. I have never put sooooo many new parts on a tractor. Tomorrow morning we're gonna play exhaust a little.
Time to create page: 0.378 seconds
