Press heavy metal + rod bender
12 Mar 2020 16:32 - 08 May 2020 13:31 #15833
Press heavy metal + rod bender was created by Geno
The 1" rod I need to bend for a project won't fit in the iron worker at the welding shop so i made a rod and flat stock bender. One change from the beginning pics is I made some copies of the press top insert so they can be welded to whatever and adapted for the press to make it more accurate, and where it will hold itself in. This will do rod up to 2" and flat stock up to 6" wide. One side does rods and the other does flat stock. Made this mostly to bend heavier stuff my finger brake won't do.
Last edit: 08 May 2020 13:31 by Geno.
12 Mar 2020 16:34 #15834
Replied by Geno on topic Press heavy metal + rod bender
This is after the design change for the top angle to fit in the press.
12 Mar 2020 16:38 #15835
Next up are some more adapters of different lengths to weld things to, and a steering wheel shaft press adapter. It gets dangerous sometimes with the bolt on the end of the press original knob lol.
12 Mar 2020 19:18 #15838
Replied by Kurt-NEPA on topic Press heavy metal + rod bender
You are make great progress Gene, Looking really good.
14 Mar 2020 18:30 #15840
Thanks guys. I think the nicest thing is that I don't have to leave the shop to do these things now. Getting closer to a full time hermit every day.
Time to create page: 0.250 seconds
