Project Clydesdale
15 Dec 2018 10:19 - 08 Feb 2019 16:41 #15038
I really shouldn't be wasting time with this but it is so much fun, and I need some fun lol...
Last edit: 08 Feb 2019 16:41 by Geno.
15 Dec 2018 10:42 #15039
by whnewone
1984 C-145
1983 C-145
1983 GT1848
1994 416-8
1984 C-145
1983 C-145
1983 GT1848
1994 416-8
15 Dec 2018 11:44 - 15 Dec 2018 11:46 #15040
Thanks Bill.
Here is some of the progression from yesterday and this morning. Frame is stripped down minus the rear pegs that I may use. The front steering bracket that was removed was cut down and moved to the rear. The steering fan was removed, it needs to be flipped the other direction. I also made a few 1/4" steel brackets to hold some things...
I should have the frame portion of the steering done by lunch today.
Last edit: 15 Dec 2018 11:46 by Geno.
15 Dec 2018 14:24 #15041
17 Dec 2018 19:34 #15046
Got most of the joint done, just needs cleanup, blasting + paint.
18 Dec 2018 16:48 #15047
19 Dec 2018 11:34 #15052
that will be something to see when its done..yeah...................................................................................................
19 Dec 2018 12:41 #15056
It should be pretty cool, but it will be pretty time consuming as well...
I am proud of my mount, as simple as it gets and does all directions.
Time to create page: 0.721 seconds
