Question for all regarding detergent and non-detergent oil usage please
- FewMoreMiles
- Banned
After a quick google search it came up with numerous write ups on this topic. It seems the topic is very subjective. Here's one that stood out to me.
www.cardwelldist.com/dev/Cardwell-Blog/N...t-For-Your-Equipment
- FewMoreMiles
- Banned
FewMoreMiles wrote: Yeah AJ, I read that article as well, and I suppose I am just curious as to whether or not a 3 minute idle and detergent SAE30 could have caused any internal damage. I guess time will tell, but for now I have opted to run the SAE30ND as suggested.
Don't worry Jeff. Detergent oil won't hurt it at all. I don't really think anyone "truly" knows why they say to use only non detergent in these engines. Its defiantly not because of age, because I know people that put it in their old hit and misses. Detergent oil is really only NEEDED in cars because A. they get used for 3000+ miles before an oil change, B. they have an oil filter, and D. there bigger engines, more cylinders, more crud. But don't worry, it won't hurt it at all.
Actually, Gary (for those who don't know him he's worked at Kohler, Briggs, and Tecumseh) and he said that the best thing you can use in these old engines, especially kohlers, is synthetic, non detergent oil. I think 10w-40.
Think of the engine like a sediment bowl type fuel filter. You want the garbage to settle at the bottom and stay there away from anything important.
Big problem with these tractors, or anything without a filter for that matter, is that is no filter to catch this stuff once a detergent oil is used and it all gets broken loose. We all know what that means...
My 51 Chevy is the same way. No filter, non-detergent only.
Geno wrote: They say to use non-detergent because there may be many years of dirt and gunk in the bottom of some of these oil pans. Once you start cleaning up the pan it all ends up in the bearings and up against the cylinder walls. Wouldn't take much time for a few hard pieces to score a cylinder wall pretty good. Who knows what lays in the pan of a 40+ year old tractor.
Ya. Might be just a good idea to take the pan off and scrape it. The kohler on my raider had a ton of crap in it. No wonder why the oil would always get black after less that 30 mins of running. Also with detergent, the sediment (mostly the smaller stuff) stays in the oil. Which will scrap the cylinder and piston, also scoring the journal on the crank.
- FewMoreMiles
- Banned
Really you shouldn't use detergent oil in any small engine without an oil filter. Even if you clean it. That way the partials in the oil that were broken up from the detergent is caught so it doesn't score the cylinder or piston, and the babbits.FewMoreMiles wrote: Sound advice guys. I have only been around newer vehicles and "toys" to speak of, and thought I would just jump in and do things as I have always done. Glad Geno made me aware of my mistake the other day, and set me down a proper course of maintenance. It definitely makes sense that, unless the oil pan is removed and the motor is thoroughly flushed (perhaps at a rebuild stage?) then it is best to run non detergent oil and let the sludge buildup rest where it has for many years.Thanks again for the elaboration and opinions on this topic. Very important for new users of older equipment!
