Starting Fluid - 520H Onan
25 Jun 2018 14:44 #14699
by GoBucks
Starting Fluid - 520H Onan was created by GoBucks
So, it cranks, but doesn't fire. If I add a little starting fluid it starts right up. This is only need for the first start of the week, if I cut it off, wash it off, etc, and get back on, it starts up fine.
Note, I was out of town for a month this time. I posted about the fuse holder, it's cranking now and just before I left at the end of May. Both times though, it didn't want to fire.
Any tips to lead me in the right direction?
Fuel filter?
Carb adjustment?
Fuel pump?
I replaced 1 spark plug before my trip. Yeah, only 1, short on time and the Previous Owner put in a full size car battery, so I can't easily get to the 2nd until I pull the battery.
Thank you,
Sam
Fuel filter?
Carb adjustment?
Fuel pump?
Thank you,
Sam
26 Jun 2018 08:18 #14700
Hey Sam. Have you tried taking the fuel line off at the filter and cranking it to see if the fuel pump is pumping?
26 Jun 2018 11:13 #14701
by GoBucks
Question, are there supposed to be 2 fuel filters on the 520H? Mine has one under the fuel tank and one by the fuel filter.
N0, I haven't tried it yet.
26 Jun 2018 15:12 #14702
Should have only 1 fuel filter above the engine.
01 Jul 2018 17:28 #14707
by GoBucks
Saturday morning, I went out to cut the grass, it cranked but wouldn't start. I then removed the hose on the input side of the fuel filter, cranked a couple seconds and gas spurted out.
So, is there a carburetor adjustment I can make to fix the No start issue? It runs great once started, and will start up again no problem.
Thank you,
Sam
Thank you,
Sam
01 Jul 2018 19:47 #14708
by GoBucks
FYI: I did replace the spark plug wires this spring.
Looking into this, it sounds like the choke might be sticking or the needles in the carb are stuck?
06 Jul 2018 10:32 #14713
by GoBucks
I figured it out, the Choke wasn't closing all the way. I took the air cleaner off, pushed the choke down all the way, and it started right up. I hit it with some carb/choke cleaner last night, I'll do it again this morning on the outside of the carb and see how it does.
14 Jan 2019 14:46 #15120
by GoBucks
The problem is the choke doesn't close all the way.
How do I adjust it? I sprayed choke cleaner inside and out.
I disconnected the choke cable where it attaches to the carb. I then pushed the choke down all the way to close. I re-attached the cable. No luck, when I moved the choke cable up and down, the choke still wouldn't close all the way.
Thank you,
Sam
Thank you,
Sam
14 Jan 2019 15:02 #15121
Does it seem like the choke is binding? Close the choke all the way with the adjustment loosened, then pull the choke lever up just a little (1/8") like you're choking it, then tighten the adjustment screw it should close fine.
28 Jan 2019 14:41 #15163
by GoBucks
Should the choke close completely?
520H choke
520H choke
Time to create page: 0.434 seconds
