Headlights
05 May 2015 07:27 #4082 by GT 14
Headlights was created by GT 14
What is the best replacement for the 4 inch sealed beams on the c-175?
05 May 2015 08:58 #4089 by M Bailey
Replied by M Bailey on topic Headlights
4411's or any par36 12 volt should fit GT. I just measured the outside diameter on the headlights in my C-165 and they are 4.4 inches, the same size as the 416-8. NAPA has the 4411's PN# LMP 4411, 35 watt sealed beam.
05 May 2015 14:46 - 05 May 2015 14:47 #4099 by GT 14
Replied by GT 14 on topic Headlights
M Bailey wrote: 4411's or any par36 12 volt should fit GT. I just measured the outside diameter on the headlights in my C-165 and they are 4.4 inches, the same size as the 416-8. NAPA has the 4411's PN# LMP 4411, 35 watt sealed beam.
Thanks Major,I measured the plastic bracket and the bezel area measured 4.0, that's why I wondered. Saw the 4411's and thought it might be to big. So it sounds like the lens must rest on the back of the bezels lip.
Last edit: 05 May 2015 14:47 by GT 14.
05 May 2015 15:25 - 05 May 2015 15:43 #4101 by M Bailey
Let me check the "bucket" measurement for you.
Last edit: 05 May 2015 15:43 by M Bailey.
05 May 2015 15:42 #4103 by M Bailey
Okay, the inside lip for the clamp/bucket measures 4.14 inches on the C-165, GT. Looks like the OD doesn't count, just the mounting diameter. Hope this helps bro.
05 May 2015 18:08 #4105 by Geno
Replied by Geno on topic Headlights
All of my Blackhoods have 4411 bulbs in them. The outer part of the bulb sits on top of the plastic. I've been meaning to get Sandra to take a pic of one here but it hasn't happened yet, sorry. :)
Ever thought about putting LED's in there? I think they make round ones that fit in there.
05 May 2015 19:03 #4110 by GT 14
M Bailey wrote: Okay, the inside lip for the clamp/bucket measures 4.14 inches on the C-165, GT. Looks like the OD doesn't count, just the mounting diameter. Hope this helps bro.
Thanks for checking Major I am ordering 4411 now, it seemed odd that it would be setup that way.
05 May 2015 19:07 #4111 by GT 14
Geno wrote: All of my Blackhoods have 4411 bulbs in them. The outer part of the bulb sits on top of the plastic. I've been meaning to get Sandra to take a pic of one here but it hasn't happened yet, sorry. :)
Thanks for checking Geno, I still like the look of old school Edison lighting.
Now to get the back end done, the plastic pan is in bad shape. Hope I can find a metal replacement.
Time to create page: 0.467 seconds
